[OpenLayers-Users] WMSGetFeatureInfo / proxy.cgi / UID and Password
	- How?
    geep999
    geep999 at yahoo.co.uk
    Sun May  6 10:52:25 EDT 2012
I'm having trouble querying features from a WMS server that requires a UID
and password.
I'm using UK Ordnance Survey's OpenSpace, which is built on OpenLayers 2.8.
OpenLayers.Layer.WMS works OK and I can see the data OK using a URL of the
form
http://UID:password@www.xxx.com
But using the same URL with OpenLayers.Control.WMSGetFeatureInfo I get
problems with the query.
I'm a bit unsure what to put into proxy.cgi.
I have tried both (1) UID:password at www.xxx.com and (2) www.xxx.com but both
produce errors attached below.
(For security I've changed some real values in the data below - e.g. myisp
for actual IP etc.).
Anybody any ideas how to solve this problem?
Cheers,
Peter
URL: http://UID:password@www.xxx.com/OGC/OGCInterface
Errors from (1) proxy.cgi has UID:password at www.xxx.com
Some unexpected error occurred. Error text was: nonnumeric port:
'password at www.xxx.com'
Errors from (2) proxy.cgi has www.xxx.com
This proxy does not allow you to access that location
(UID:password at www.xxx.com).
{'HTTP_COOKIE':
'__utma=269788912.1267851037.1310233790.1334770471.1335197005.120;
__utmz=269788912.1334770471.119.78.utmcsr=bing|utmccn=(organic)|utmcmd=organic|utmctr=bt21cn;
__utmc=269788912', 'SERVER_SOFTWARE':
'Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8e-fips-rhel5
mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635',
 'SCRIPT_NAME': '/gpx/proxy.cgi', 'SERVER_SIGNATURE': '
 Server at myserver.co.uk Port 80
\n', 'REQUEST_METHOD': 'GET', 'SERVER_PROTOCOL': 'HTTP/1.1', 'QUERY_STRING':
'url=http%3A%2F%2FUID%3Apassword%40www.xxx.com%2FOGC%2FOGCInterface%3Fservice%3DWMS%26version%3D1.1.0%26request
%3DGetFeatureInfo%26layers%3Deainspire2011-wms-drn_inspire-wm%26query_layers%3Deainspire2011-wms-drn_inspire-wm%26styles%3D%26bbox
%3D546742.276473%252C232929.256534%252C559162.276473%252C241299.256534%26srs%3DEPSG%253A27700%26feature_count%3D10%26x%3D859%26y
%3D261%26height%3D837%26width%3D1242%26info_format%3Dtext%252Fhtml', 'PATH':
'/usr/local/bin:/usr/bin:/bin',
 'HTTP_USER_AGENT': 'Mozilla/5.0 (X11; Linux x86_64; rv:11.0) Gecko/20100101
Firefox/11.0', 'HTTP_CONNECTION': 'keep-alive',
 'HTTP_REFERER': 'http://myserver.co.uk/gpx/rivers.html', 'SERVER_NAME':
'myserver.co.uk', 'REMOTE_ADDR': '109.170.137.226',
 'SERVER_PORT': '80', 'SERVER_ADDR': '84.234.17.171', 'DOCUMENT_ROOT':
'/home/myid/public_html', 'SCRIPT_FILENAME':
 '/home/myid/public_html/gpx/proxy.cgi', 'SERVER_ADMIN':
'webmaster at myid.myisp.co.uk', 'HTTP_HOST': 'myserver.co.uk',
 'REQUEST_URI':
'/gpx/proxy.cgi?url=http%3A%2F%2FUID%3Apassword%40www.xxx.com%2FOGC%2FOGCInterface
%3Fservice%3DWMS%26version%3D1.1.0%26request%3DGetFeatureInfo%26layers%3Deainspire2011-wms-drn_inspire-wm%26query_layers
%3Deainspire2011-wms-drn_inspire-wm%26styles%3D%26bbox%3D546742.276473%252C232929.256534%252C559162.276473%252C241299.256534
%26srs%3DEPSG%253A27700%26feature_count%3D10%26x%3D859%26y%3D261%26height%3D837%26width%3D1242%26info_format%3Dtext%252Fhtml',
 'HTTP_ACCEPT':
'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8',
'GATEWAY_INTERFACE': 'CGI/1.1', 'REMOTE_PORT':
 '49074', 'HTTP_ACCEPT_LANGUAGE': 'en-us,en;q=0.5', 'HTTP_ACCEPT_ENCODING':
'gzip, deflate'}
View this message in context: http://osgeo-org.1560.n6.nabble.com/WMSGetFeatureInfo-proxy-cgi-UID-and-Password-How-tp4955910.html
