AW: [OpenLayers-Users] Different level of detail at different
zoomlevel on open layer map
Morper-Busch, Lucia
Lucia.Morper-Busch at sbg.ac.at
Tue May 8 10:37:29 EDT 2012
Hello,
do you use Geoserver and SLD-files?
http://docs.geoserver.org/stable/en/user/styling/sld-cookbook/index.html
Then have a look at the sld examples, especially minscaledenominator and maxscaledenominator for setting the scale in which the layer or feature is visible.
Lucia
Dipl.-Geogr. Lucia Morper-Busch | Researcher
University of Salzburg | Centre for Geoinformatics - Z_GIS
Schillerstr.30 | Techno-Z, Block 15, 3rd floor, Room 320 | 5020 Salzburg, Austria
Phone +43 (0)662 8044 5298 | Fax +43 (0)662 8044 5260
> Z_GIS...experts for the spatial view
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von sacprasanna
Gesendet: Dienstag, 08. Mai 2012 13:31
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] Different level of detail at different zoomlevel on open layer map
Hi all,
I want display different detail(layers) on different zoom level on open layer map.I mean when zoom in should display lot of layers and when zoom out those unsuitable layers should hide automatically. Different layers should display on different zoom level not using layer switcher.
Can this do using open layers?
If not what is the open source solution?
If yes,Pls give some example or links to get some idea
Thanks for reading and answering
View this message in context: http://osgeo-org.1560.n6.nabble.com/Different-level-of-detail-at-different-zoom-level-on-open-layer-map-tp4960173.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
