[OpenLayers-Users] Re: Different level of detail at different zoom
level on open layer map
sacprasanna
sacprasanna at gmail.com
Tue May 8 09:42:55 EDT 2012
Thanks Fernando,
I will try using that link.Hope we will contact again
On 5/8/12, Fernando Norte [via OSGeo.org]
<ml-node+s1560n4960228h96 at n6.nabble.com> wrote:
> http://trac.osgeo.org/openlayers/wiki/SettingZoomLevels
> *Fernando Norte*
> Desenvolvedor SIGWeb
> tel.(31) 2533.9900
> cel.(31) 9119.8814
> skype: fernandoglobalgeo
> Endereço: Alameda do Ingá, 88, 6º andar, Vale do Sereno
> Nova Lima/MG - CEP: 34.000-000
> www.globalgeo.com.br
> "O presente documento pode conter material confidencial ou seu sigilo é
> protegido por lei.
> Quaisquer informações nele contida são destinadas exclusivamente ao(s)
> seu(s) destinatário(s)
> não devendo em nenhuma hipótese ser repassado a terceiros".
> 2012/5/8 sacprasanna <sacprasanna at gmail.com>
>> Hi all,
>> I want display different detail(layers) on different zoom level on open
>> layer map.I mean when zoom in should display lot of layers and when zoom
>> out
>> those unsuitable layers should hide automatically. Different layers
>> should
>> display on different zoom level not using layer switcher.
>> Can this do using open layers?
>> If not what is the open source solution?
>> If yes,Pls give some example or links to get some idea
>> Thanks for reading and answering
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Different-level-of-detail-at-different-zoom-level-on-open-layer-map-tp4960173.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/Different-level-of-detail-at-different-zoom-level-on-open-layer-map-tp4960173p4960228.html
> To unsubscribe from Different level of detail at different zoom level on
> open layer map, visit
> http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4960173&code=c2FjcHJhc2FubmFAZ21haWwuY29tfDQ5NjAxNzN8LTIwMzA3MDM5NjY=
View this message in context: http://osgeo-org.1560.n6.nabble.com/Different-level-of-detail-at-different-zoom-level-on-open-layer-map-tp4960173p4960482.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120508/dd6f7518/attachment.html
