[OpenLayers-Users] Google map v3 popup again?
Harris Hudson
hhudson at katmandu.org
Wed May 16 22:58:55 PDT 2012
Tim,
Thank you very much - it works as you described.
Harris.
> Hi Harris
> On Wed, May 16, 2012 at 10:03 PM, Harris Hudson wrote:
>> Today I noticed a Google copyright popup appearing again. Is there are
>> workaround/fix to this problem?
> Thanks for alerting me to this issue. I don't watch my maps very often
> during the year.
> I fixed the problem by adding the following line to the
> OpenLayers-2.11/theme/default/style.css file. However, I still see
> that the Google map attributes have a white background and the
> positioning seems a bit weird. At least this kills the pop-up.
> .olLayerGooglePoweredBy.olLayerGoogleV3.gmnoprint {
> visibility:hidden;
> Hope this helps.
> --Tim
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
