[OpenLayers-Users] Google map v3 popup again?
Zac Spitzer
zac.spitzer at gmail.com
Thu May 17 00:58:49 PDT 2012
um, aren't you violating the Google maps api TOS ?
On Thu, May 17, 2012 at 3:58 PM, Harris Hudson <hhudson at katmandu.org> wrote:
> Tim,
> Thank you very much - it works as you described.
> Harris.
>> Hi Harris
>> On Wed, May 16, 2012 at 10:03 PM, Harris Hudson wrote:
>>> Today I noticed a Google copyright popup appearing again. Is there are
>>> workaround/fix to this problem?
>> Thanks for alerting me to this issue. I don't watch my maps very often
>> during the year.
>> I fixed the problem by adding the following line to the
>> OpenLayers-2.11/theme/default/style.css file. However, I still see
>> that the Google map attributes have a white background and the
>> positioning seems a bit weird. At least this kills the pop-up.
>> .olLayerGooglePoweredBy.olLayerGoogleV3.gmnoprint {
>> visibility:hidden;
>> Hope this helps.
>> --Tim
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
