[OpenLayers-Users] Google map v3 popup again?
    Harris Hudson
    hhudson at katmandu.org
    Thu May 17 01:12:09 PDT 2012
The Google logo and attribution is still shown on
the map but maybe you are right - who could advise?
Perhaps we need the devs to check if this workaround
is acceptable.
Harris.
> um, aren't you violating the Google maps api TOS ?
> On Thu, May 17, 2012 at 3:58 PM, Harris Hudson <hhudson at katmandu.org>
> wrote:
>> Tim,
>> Thank you very much - it works as you described.
>> Harris.
>>> Hi Harris
>>> On Wed, May 16, 2012 at 10:03 PM, Harris Hudson wrote:
>>>> Today I noticed a Google copyright popup appearing again.  Is there
>>>> are
>>>> workaround/fix to this problem?
>>> Thanks for alerting me to this issue. I don't watch my maps very often
>>> during the year.
>>> I fixed the problem by adding the following line to the
>>> OpenLayers-2.11/theme/default/style.css file. However, I still see
>>> that the Google map attributes have a white background and the
>>> positioning seems a bit weird. At least this kills the pop-up.
>>> .olLayerGooglePoweredBy.olLayerGoogleV3.gmnoprint {
>>> visibility:hidden;
>>> Hope this helps.
>>> --Tim
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Users mailing list
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
