[OpenLayers-Users] Google map v3 popup again?
Zac Spitzer
zac.spitzer at gmail.com
Thu May 17 01:16:40 PDT 2012
I'd recommend always assuming it has to be unless you know otherwise
http://openlayers.org/blog/2010/07/10/google-maps-v3-for-openlayers/#comment-36049
On Thu, May 17, 2012 at 6:12 PM, Harris Hudson <hhudson at katmandu.org> wrote:
> The Google logo and attribution is still shown on
> the map but maybe you are right - who could advise?
> Perhaps we need the devs to check if this workaround
> is acceptable.
> Harris.
>> um, aren't you violating the Google maps api TOS ?
>> On Thu, May 17, 2012 at 3:58 PM, Harris Hudson <hhudson at katmandu.org>
>> wrote:
>>> Tim,
>>> Thank you very much - it works as you described.
>>> Harris.
>>>> Hi Harris
>>>> On Wed, May 16, 2012 at 10:03 PM, Harris Hudson wrote:
>>>>> Today I noticed a Google copyright popup appearing again. Is there
>>>>> are
>>>>> workaround/fix to this problem?
>>>> Thanks for alerting me to this issue. I don't watch my maps very often
>>>> during the year.
>>>> I fixed the problem by adding the following line to the
>>>> OpenLayers-2.11/theme/default/style.css file. However, I still see
>>>> that the Google map attributes have a white background and the
>>>> positioning seems a bit weird. At least this kills the pop-up.
>>>> .olLayerGooglePoweredBy.olLayerGoogleV3.gmnoprint {
>>>> visibility:hidden;
>>>> Hope this helps.
>>>> --Tim
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>> Users mailing list
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
Zac Spitzer
+61 405 847 168
