[OpenLayers-Users] Google map v3 popup again?
Andreas Hocevar
ahocevar at opengeo.org
Thu May 17 01:27:22 PDT 2012
This hack definitely violates the Terms of Use.
The reason for the reappearing popup is tht th 3.6 version of the GMaps API
is no longer available, so you get 3.7 now even if you request 3.6.
Until somebody provides a fix in OpenLayers, my advice is to use a
different base map.
Andreas.
On Thursday, May 17, 2012, Tim Baggett <tim.baggett at gmail.com> wrote:
> Hi Harris
> On Wed, May 16, 2012 at 10:03 PM, Harris Hudson wrote:
>> Today I noticed a Google copyright popup appearing again. Is there are
>> workaround/fix to this problem?
> Thanks for alerting me to this issue. I don't watch my maps very often
> during the year.
> I fixed the problem by adding the following line to the
> OpenLayers-2.11/theme/default/style.css file. However, I still see
> that the Google map attributes have a white background and the
> positioning seems a bit weird. At least this kills the pop-up.
> .olLayerGooglePoweredBy.olLayerGoogleV3.gmnoprint {
> visibility:hidden;
> Hope this helps.
> --Tim
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120517/57122b18/attachment.html
