[OpenLayers-Users] jquery draggable item to go on top of my
openlayers map
jdmorgan
jdmorgan at unca.edu
Wed May 23 09:06:17 PDT 2012
Thanks Jerome. You suggestion did indeed work.
Cheers,
Derek
On 5/23/2012 8:03 AM, jrom wrote:
> Hi,
> Did you try to add a higher z-index to your #draggable object ?
> #draggable { width: 150px; height: 150px; padding: 0.5em;z-index:10000}
> Regards
> Jerome
> http://mapshup.info
> 2012/5/21 jdmorgan<jdmorgan at unca.edu>:
>> Hello,
>> I am trying to get a jquery draggable item to go on top of my openlayers
>> map. Unfortunately it always goes behind the map. Does anyone in this
>> community have any experience with this that can point me in the right
>> direction? Here is my code:
>> <html xmlns="http://www.w3.org/1999/xhtml">
>> <head>
>> <title>NEMAC OpenLayers GIS Viewer Dev</title>
>> <script src="libs/ol21/lib/OpenLayers.js"></script>
>> <script type="text/javascript" src="libs/jquery18/jquery-1.7.2.js"></script>
>> <script type="text/javascript" src="test.js"></script>
>> <link rel="stylesheet" href="libs/jquery18/themes/base/jquery.ui.all.css">
>> <script src="libs/jquery18/ui/jquery.ui.core.js"></script>
>> <script src="libs/jquery18/ui/jquery.ui.widget.js"></script>
>> <script src="libs/jquery18/ui/jquery.ui.mouse.js"></script>
>> <script src="libs/jquery18/ui/jquery.ui.draggable.js"></script>
>> <link rel="stylesheet" href="../demos.css">
>> </head>
>> <style>
>> body {
>> margin: 0;
>> padding: 0;
>> #banner {
>> background-color: Whitesmoke;
>> margin: 0;
>> padding: 1px 0 0 0;
>> #mainMenu {
>> width:100%;
>> margin-bottom:.2em;
>> #content {
>> width:100%;
>> #draggable { width: 150px; height: 150px; padding: 0.5em;}
>> </style>
>> <script>
>> $(function() {
>> $( "#draggable" ).draggable();
>> </script>
>> <body onload="init();">
>> <div id="draggable" class="ui-widget-content">
>> <p>Drag me around</p>
>> </div>
>> <div id="banner">
>> NEMAC OpenLayers Viewer
>> <div id="mainMenu" align="center">
>> Theme:<select id="themeCombo"></select>
>> </div>
>> </div>
>> <div id="content">
>> <div id="mainMap"></div>
>> </div>
>> </body>
>> </html>
>> Derek @ NEMAC
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Derek @ NEMAC
http://nemac.unca.edu
