[OpenLayers-Users] Pink broken images
Smaran Harihar
smaran.harihar at gmail.com
Wed May 23 15:29:41 PDT 2012
Hi Gery,
Thanks for the reply, I was able to resolve some of the errors. Ok the
openlayer docs said that Geoserver is compatible with EPSG:900913 so I
removed any projections and it now overlays fine. But there is some shift
between my WMS base layer and OSM and GMap.
Also the new problem that I am facing is that the lat and long that is
displayed in the control is fine if I display my WMS, but if I change the
basemap to OSM or GMap again the lat long goes haywire. Also the other WMS
with property 'isBaseLayer': false is overlaid on my WMS basemap but not on
OSM and GMaps. (Which was happening earlier).
Any suggesstions?
Thanks & Regards,
Smaran Harihar
On Wed, May 23, 2012 at 1:27 PM, Gery . <gamejihou at hotmail.com> wrote:
> Hello,
> I think this link may help you about 1 and 2:
> http://gis.stackexchange.com/questions/26030/sometimes-a-white-square-dialogue-appears-in-the-middle-of-the-screen-map-data
> I think 3 is because of the projection, google maps only works with
> 900913, so you have to add a line, if I remember well, almost at the end of
> your <script> tag to do the conversion, or it is something about proj, not
> sure because Im writing from memory, take a look here anyway:
> http://docs.openlayers.org/library/spherical_mercator.html
> Hope this helps, cheers :)
> From: smaran.harihar at gmail.com
> Date: Wed, 23 May 2012 11:52:51 -0700
> To: openlayers-users at lists.osgeo.org
> Subject: [OpenLayers-Users] Pink broken images
> Hi,
> I am trying to create a base map of OSM, Google Roadmap and Google Hybrid
> and mash it up with my own base layers in Geoserver. So these are the
> problems I am facing,
> 1. I have two WMS that I am mashing up, on which is BaseLayer and another
> one is 'isBaseLayer' : false. The one with base layer is appearing as pink
> tiles with broken image and the 'isBaseLayer': false is rending perfectly
> over OSM, GoogleMaps. Any reason y? I have changed the projections using
> the following code,
> var geographic = new OpenLayers.Projection("EPSG:4326");
> var mercator = new OpenLayers.Projection("EPSG:900913");
> var world = new OpenLayers.Bounds(-180, -60, 180,
> 90).transform(geographic, mercator);
> //var center = new OpenLayers.LonLat(-104.98, 39.76).transform(geographic,
> mercator);
> var options = {
> projection : mercator,
> units : "m",
> maxExtent : world
> var map = new OpenLayers.Map("map-id", options);
> 2. Since I have added the Google Maps and I am using v3.2, there is this
> splash screen appears every time the map loads or if i pan it around. How
> can i remove that screen? I close it by clicking on the cross and then
> again pan or click on the map and there it is again.
> 3. When I had initially added my two baselayers, the map control which got
> the lat and lon was giving the right co-ordinates but when I added the OSM
> and GMaps, the co-ordinates are completely different. Why is that? Is it
> because of the spherical Mercator? How can I make it right?
> Thanks & Regards
> Smaran Harihar
> _______________________________________________ Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Thanks & Regards
Smaran Harihar
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120523/170f19de/attachment-0001.html
