[OpenLayers-Users] Pink broken images
Gery .
gamejihou at hotmail.com
Wed May 23 13:27:02 PDT 2012
Hello,
I think this link may help you about 1 and 2: http://gis.stackexchange.com/questions/26030/sometimes-a-white-square-dialogue-appears-in-the-middle-of-the-screen-map-data
I think 3 is because of the projection, google maps only works with 900913, so you have to add a line, if I remember well, almost at the end of your <script> tag to do the conversion, or it is something about proj, not sure because Im writing from memory, take a look here anyway: http://docs.openlayers.org/library/spherical_mercator.html
Hope this helps, cheers :)
Date: Wed, 23 May 2012 11:52:51 -0700
To: openlayers-users at lists.osgeo.org
Subject: [OpenLayers-Users] Pink broken images
I am trying to create a base map of OSM, Google Roadmap and Google Hybrid and mash it up with my own base layers in Geoserver. So these are the problems I am facing,
1. I have two WMS that I am mashing up, on which is BaseLayer and another one is 'isBaseLayer' : false. The one with base layer is appearing as pink tiles with broken image and the 'isBaseLayer': false is rending perfectly over OSM, GoogleMaps. Any reason y? I have changed the projections using the following code,
var geographic = new OpenLayers.Projection("EPSG:4326"); var mercator = new OpenLayers.Projection("EPSG:900913");
var world = new OpenLayers.Bounds(-180, -60, 180, 90).transform(geographic, mercator); //var center = new OpenLayers.LonLat(-104.98, 39.76).transform(geographic, mercator);
var options = { projection : mercator, units : "m",
maxExtent : world };
var map = new OpenLayers.Map("map-id", options);
2. Since I have added the Google Maps and I am using v3.2, there is this splash screen appears every time the map loads or if i pan it around. How can i remove that screen? I close it by clicking on the cross and then again pan or click on the map and there it is again.
3. When I had initially added my two baselayers, the map control which got the lat and lon was giving the right co-ordinates but when I added the OSM and GMaps, the co-ordinates are completely different. Why is that? Is it because of the spherical Mercator? How can I make it right?
Thanks & RegardsSmaran Harihar
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120523/410b4069/attachment.html
