[OpenLayers-Users] WMS
Arnd Wippermann
arnd.wippermann at web.de
Fri Nov 2 15:50:25 PDT 2012
var layer = new OpenLayers.Layer.WMS(name, params, options)
the param SRS is set by OpenLayers using the map projection. But you could
overwrite the projection,
if you set in the options projection:"EPSG:102113".
// WMS LAYER: National Elevation Dataset - EROS
var layer = new OpenLayers.Layer.WMS( "National Elevation Dataset - EROS",
"http://imsref.cr.usgs.gov:80/wmsconnector/com.esri.wms.Esrimap/USGS_EDC_Ele
v_NED?",
{layers: "NED.CONUS_NED,NED.PR_NED",
TRANSPARENT:true, format: "image/png"},
{isBaseLayer: false, visibility: true, group:"other", opacity: 0.75,
meta:true, projection:"EPSG:102113"});
map.addLayer(layer);
Also the projection is declared with the prefix EPSG.
srs:EPSG:102113 instead srs:102113.
Arnd
_____
Von: Doug Kunzman [mailto:dkunzman at usgs.gov]
Gesendet: Freitag, 2. November 2012 23:13
An: arnd.wippermann at web.de
Betreff: Re: AW: [OpenLayers-Users] WMS
Arnd -
Something weird is happening with the request because this is my code to
setup layer in openlayers. This is from firebug so I'm sure its not a cache
issue.
<http://imsref.cr.usgs.gov/wmsconnector/com.esri.wms.Esrimap/USGS_EDC_Elev_N
ED?>
http://imsref.cr.usgs.gov:80/wmsconnector/com.esri.wms.Esrimap/USGS_EDC_Elev
_NED?",
srs: "102113", TRANSPARENT:true, format: "image/png"},
{isBaseLayer: false, visibility: false, group:"other", opacity: 0.75,
meta:true});
And this is the request from firebug
BBOX -11075419.648867,4569099.8021387,-11065635.709248,4578883.7417578
FORMAT image/png
HEIGHT 256
LAYERS NED.CONUS_NED,NED.PR_NED
REQUEST GetMap
SERVICE WMS
SRS EPSG:3857
STYLES
TRANSPARENT TRUE
VERSION 1.1.1
WIDTH 256
I think its a open layers issue but the bbox parameters look like 102113.
Douglas Kunzman
12201 Sunrise Valley Drive
Reston, VA 20192
Phone: 703 648-4234
From: "Arnd Wippermann" <arnd.wippermann at web.de>
To: "'Doug Kunzman'" <dkunzman at usgs.gov>
Cc: <openlayers-users at lists.osgeo.org>
Date: 11/02/2012 06:00 PM
Subject: AW: [OpenLayers-Users] WMS
_____
EPSG:3857 is not supported by the wms, see
<http://ims.cr.usgs.gov/WMS_Capabilities/USGS_EDC_Elev_NED/capabilities_1_1_
1.xml>
http://ims.cr.usgs.gov/WMS_Capabilities/USGS_EDC_Elev_NED/capabilities_1_1_1
.xml
but you can use EPSG:102113 instead.
NED above Google using EPSG:102113 for request
<http://gis.ibbeck.de/OLClient/OLClient.asp?WMC=./data/WMC/USGS_EDC_Elev_NED
_102113.wmc.xml>
http://gis.ibbeck.de/OLClient/OLClient.asp?WMC=./data/WMC/USGS_EDC_Elev_NED_
102113.wmc.xml
Arnd
_____
Von: openlayers-users-bounces at lists.osgeo.org [
<mailto:openlayers-users-bounces at lists.osgeo.org>
mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Doug Kunzman
Gesendet: Freitag, 2. November 2012 18:49
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] WMS
Hi -
I trying to include the EROS data set as part of the National Map at USGS in
an open Layers project. We are using a spherical Mercator projection
"102113" which would be hard to change at this point. My requests work when
they are in latitude and longitude but my requests fail when they are in
spherical mecator. Is there any way to force open layers to make my request
with reprojected parameters as latitude longitude rather than spherical
Mercator?
This isn't working
BBOX -10018754.17,-1.862645149231e-9,-5009377.085,5009377.085
FORMAT image/png
HEIGHT 256
REQUEST GetMap
SERVICE WMS
SRS EPSG:3857
STYLES
VERSION 1.1.1
The end point of the service is at this location.
ED?>
http://imsref.cr.usgs.gov/wmsconnector/com.esri.wms.Esrimap/USGS_EDC_Elev_NE
D?
Thanks,
Douglas Kunzman
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121102/bcd7de70/attachment-0001.html>
