[OpenLayers-Users] How To: Positionate WGS84 tracks intoGauss-Boaga Map
Arnd Wippermann
arnd.wippermann at web.de
Sun Nov 4 14:08:35 PST 2012
use of proj4js to transform coordinates from EPSG:4326 to EPSG:3004
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL212/PointTrack_Boaga_Projection
.asp
the map projection is EPSG:3004, the coordinates in the kml-file are in
projection EPSG:4326.
The proj4js projection string
Proj4js.defs["EPSG:3004"] = "+proj=tmerc +lat_0=0 +lon_0=15 +k=0.9996
+x_0=2520000 +y_0=0 +ellps=intl +units=m +no_defs";
comes from http://spatialreference.org/ref/epsg/3004/proj4js/
Good luck
Arnd
_____
Von: Riggi Valerio [mailto:vash.84 at virgilio.it]
Gesendet: Samstag, 3. November 2012 12:56
An: arnd.wippermann at web.de
Cc: openlayers-users at lists.osgeo.org
Betreff: Re: AW: [OpenLayers-Users] How To: Positionate WGS84 tracks
intoGauss-Boaga Map
By the way: How did you manage to show a tif in your browser?
I manage to show the tiff only on Internet Explorer (using
OpenLayers.Layer.Image), but it is not a problem because it is for a
univerity exam..
then you have to add the proj4js javascript library to your application.
Can you show me an example?
This is the Current Track Layer:
new OpenLayers.Layer.PointTrack("Tracks", {
projection: geographic,
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: "track.kml",
format: new OpenLayers.Format.KML({
extractTracks: true,
extractStyles: true
dataFrom: OpenLayers.Layer.PointTrack.TARGET_NODE,
styleFrom: OpenLayers.Layer.PointTrack.TARGET_NODE,
eventListeners: {
"beforefeaturesadded": function(e) {
// group the tracks by fid and create one track for
// every fid
var fid, points = [], feature;
for (var i=0, len=e.features.length; i<len; i++) {
feature = e.features[i];
if ((fid && feature.fid !== fid) || i === len-1)
this.addNodes(points, {silent: true});
points = [];
} else {
points.push(feature);
fid = feature.fid;
return false;
Many Thank's
Valerio
Il 02/11/2012 22:59, Arnd Wippermann ha scritto:
if you want reproject feature coordinates from EPSG:4326 (WGS84) to other
projection than EPSG:900913 (SphericalMercator),
Arnd
_____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Riggi
Valerio
Gesendet: Freitag, 2. November 2012 21:56
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] How To: Positionate WGS84 tracks intoGauss-Boaga
Map
Hi, I'm tring to track some gps data into a Gauss-Boaga map, but I don't
manage to put the track on the right place, how can I do?
This is the Track layer:
url: "track.kml",
extractStyles: true
eventListeners: {
// every fid
points = [];
} else {
fid = feature.fid;
return false;
And this is the Gauss-Boaga Projection:
var options = {
isBaseLayer: true,
maxResolution: '0.84686783985005',
displayInLayerSwitcher: true,
size: new OpenLayers.Size(8745, 6696),
numZoomLevels: 20
var gauss = new OpenLayers.Layer.Image(
'Gauss-Boaga',
'CTR588140.tif',
new OpenLayers.Bounds(2556348.9846319141797721,
4227924.4383069388568401,
2563754.8438914027065039,4233595.0653625745326281), <?php
//left,bottom,right,top ?>
options
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121104/d1467633/attachment-0001.html>
