[OpenLayers-Users] tilecache
Gery .
gamejihou at hotmail.com
Sun Nov 4 07:55:23 PST 2012
thanks Diego for the tip, my MAP file has both epsg.4326 (ie. postgis tables) and epsg:900913 at the same object level, that`s why the postgis layers are displayed in openlayers over google (satellite, maps, etc...) when I use the whole link (ie. using mapserv). If I use tilecache this doesnt work, no idea why.
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
> From: diegoguidi at gmail.com
> Date: Sun, 4 Nov 2012 13:52:45 +0100
> Subject: Re: [OpenLayers-Users] tilecache
> To: gamejihou at hotmail.com
> CC: openlayers-users at lists.osgeo.org
> > those are served by mapserver using an extent in decimal degrees
> you should tell mapserver to transform data to EPSG:900913
> to me, looks a wrong mapserver configuration.
> http://mapserver.org/mapfile/projection.html
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121104/f9af77b2/attachment.html>
