[OpenLayers-Users] tilecache
Diego Guidi diegoguidi at gmail.com
Sun Nov 4 13:17:39 PST 2012
you should also tell tilecache the srs to use.
http://crschmidt.net/blog/archives/311/using-tilecache-with-google-maps-and-virtual-earth/
Diego Guidi
On Sun, Nov 4, 2012 at 4:55 PM, Gery . <gamejihou at hotmail.com> wrote:
> thanks Diego for the tip, my MAP file has both epsg.4326 (ie. postgis
> tables) and epsg:900913 at the same object level, that`s why the postgis
> layers are displayed in openlayers over google (satellite, maps, etc...)
> when I use the whole link (ie. using mapserv). If I use tilecache this
> doesnt work, no idea why.
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO
> es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie
> NICHT, wenn es NICHT notwendig ist.
>> From: diegoguidi at gmail.com
>> Date: Sun, 4 Nov 2012 13:52:45 +0100
>> Subject: Re: [OpenLayers-Users] tilecache
>> To: gamejihou at hotmail.com
>> CC: openlayers-users at lists.osgeo.org
>> > those are served by mapserver using an extent in decimal degrees
>> you should tell mapserver to transform data to EPSG:900913
>> to me, looks a wrong mapserver configuration.
>> http://mapserver.org/mapfile/projection.html
