[OpenLayers-Users] Ancillary question on the tileerror event handling - overriding default css behaviour.[SEC=UNOFFICIAL]
Robert Mcauliffe
r.mcauliffe at bom.gov.au
Sun Nov 4 20:00:44 PST 2012
Phil,
You try overriding the css in your event handler:
layer.events.register("tileerror",layer,function(evt){
evt.tile.setImgSrc("images/empty.png");
var imgDiv = evt.object.imgDiv;
imgDiv.style.visibility='visible';
return false;
Note that I haven't actually tested this, so YMMV and good luck!
(also note that if you use some sort of DOM library like jQuery, then the 4th line should probably use whatever css-setting facility that library has)
Cheers,
Rob
-----Original Message-----
From: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Phil Scadden
Sent: Monday, 5 November 2012 2:09 PM
To: openlayers-users at lists.osgeo.org
Subject: [OpenLayers-Users] Ancillary question on the tileerror event handling - overriding default css behaviour.
Mostly, i deal with load errors from tiles with a css entry .olImageLoadError {
display: none;
For my osm, I wanted to deal with it a blank ocean tile which I did with
return false;
However, the css entry turns off the tile! (works fine if I remove the css). Is there an easy way to change that?
Phil Scadden, GNS Science Ltd 764 Cumberland St, Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
