[OpenLayers-Users] base layers with different projection in the same map
Phil Scadden
p.scadden at gns.cri.nz
Wed Nov 7 12:58:40 PST 2012
WMS sends images. There is no realistic way to reproject the tile
images. If you change the map projection, then OL will request the WMS
servers to send tiles in the new projection. I understood that the
layers would be re-requested if the base layer changed to a different
projection but if not, you could force the redraw explicitly. If you
have a WMS server that only sends 900913 (eg google) and one that only
sends 4326, you then are basically stuffed - they cannot be mixed.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
