[OpenLayers-Users] How do I set attributes when creating vectors using WFS-T?
Alexandre Dubé
adube at mapgears.com
Thu Nov 15 05:39:58 PST 2012
Hello,
If you look at OpenLayers/Feature/Vector.js, you'll see the
"attributes" property :
http://dev.openlayers.org/releases/OpenLayers-2.12/doc/apidocs/files/OpenLayers/Feature/Vector-js.html#OpenLayers.Feature.Vector.attributes
It is where the attribute properties describing a feature are kept.
Using Firebug/Any browser dev tool, you can inspect your layer feature
object, using layer.features[0].attributes.
So, after drawing your feature you could open a popup and display a
form containing the fields you want to have as your feature attributes.
Once done, for each field you would do :
feature.attribute['myfieldname'] = field.value.
That's basically what the [example] does. If you look at the
[source] code, search for parseFeatureAttributesToForm and
parseFormAttributesToFeature methods. This is pretty old stuff, but you
should be able to understand it.
Let us know if you need more help. It'd be nice to have a small live
demo of your application so that we could see what you're trying to do.
[example] http://dev4.mapgears.com/bdga/bdgaWFS-T.html
[source] http://dev4.mapgears.com/bdga/bdgaRoads.js
HTH,
Alexandre
On 12-11-15 04:04 AM, jannesm wrote:
> Any ideas?
> I found these links related to the issue, but most are unanswered or the
> answer is a bit complex. Is there an easy way to do this?
> I want to edit corresponding postgresql data of a vector from
> openlayers- how to do it?
> http://gis.stackexchange.com/questions/1982/i-want-to-edit-corresponding-postgresql-data-of-a-vector-from-openlayers-how-to?rq=1
> How to edit Attributes on WFS Layer through Popup?
> http://gis.stackexchange.com/questions/31753/how-to-edit-attributes-on-wfs-layer-through-popup
> How to edit feature attributes with openlayers?
> http://gis.stackexchange.com/questions/30162/how-to-edit-feature-attributes-with-openlayers
> Modify WFS with OpenLayers
> http://gis.stackexchange.com/questions/30081/modify-wfs-with-openlayers
> adding non spatial attributes using geoserver
> http://gis.stackexchange.com/questions/32243/adding-non-spatial-attributes-using-geoserver?rq=1
> How to insert non-spatial data through WFS-T insert?
> http://gis.stackexchange.com/questions/31915/how-to-insert-non-spatial-data-through-wfs-t-insert?rq=1
> Also an example: http://dev4.mapgears.com/bdga/bdgaWFS-T.html#
> View this message in context: http://osgeo-org.1560.n6.nabble.com/How-do-I-set-attributes-when-creating-vectors-using-WFS-T-tp5015040p5016525.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Alexandre Dubé
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121115/55a5ec80/attachment.html>
