[OpenLayers-Users] WMSGetFeatureInfo show data from other layer in custom popup
Paul Meems bontepaarden at gmail.com
Thu Nov 22 03:54:41 PST 2012
Yes Bart I'm using GeoServer.
It seems 'Cross-layer filtering' is exactly what I need.
I will investigate it further.
Bedankt,
Paul
2012/11/22 Bart van den Eijnden <bartvde at opengeo.org>
> What WMS are you using?
> If you're using GeoServer, check out:
> http://docs.geoserver.org/latest/en/user/extensions/querylayer/index.html
> Best regards,
> Bart
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> On Nov 22, 2012, at 11:46 AM, Paul Meems <bontepaarden at gmail.com> wrote:
>  I have two layers:
> * Buildings
> * Roof tops
> I now have implemented OpenLayers.Control.WMSGetFeatureInfo on the roof
> tops layer.
> This works great and a popup is shown with the data.
> I want to change this so that WMSGetFeatureInfo works on the Buildings
> layer.
> I know how to do that, but instead of showing the data of the building I
> want to show the data of the roof tops that belong to that building.
> I can get the roof tops using the building ID but how do I make
> WMSGetFeatureInfo fill my popup with the roof top data?
> I think I need to call a php-file that returns a json string with the data.
> I'm doing something similar when looking for addresses.
> I also need to change the popup so that every roof top gets its own tab.
> Any advice would be much appreciated.
> Thanks,
> Paul
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121122/e94278ff/attachment.html>
