[OpenLayers-Users] WMSGetFeatureInfo show data from other layer in custom popup
Bart van den Eijnden
bartvde at opengeo.org
Thu Nov 22 02:58:15 PST 2012
What WMS are you using?
If you're using GeoServer, check out:
http://docs.geoserver.org/latest/en/user/extensions/querylayer/index.html
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Nov 22, 2012, at 11:46 AM, Paul Meems <bontepaarden at gmail.com> wrote:
> I have two layers:
> * Buildings
> * Roof tops
> I now have implemented OpenLayers.Control.WMSGetFeatureInfo on the roof tops layer.
> This works great and a popup is shown with the data.
> I want to change this so that WMSGetFeatureInfo works on the Buildings layer.
> I know how to do that, but instead of showing the data of the building I want to show the data of the roof tops that belong to that building.
> I can get the roof tops using the building ID but how do I make WMSGetFeatureInfo fill my popup with the roof top data?
> I think I need to call a php-file that returns a json string with the data.
> I'm doing something similar when looking for addresses.
> I also need to change the popup so that every roof top gets its own tab.
> Any advice would be much appreciated.
> Thanks,
> Paul
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121122/fc570587/attachment.html>
