[OpenLayers-Users] legend "floating" over map - Calling Alexandre Dube!
Gery .
gamejihou at hotmail.com
Tue Nov 27 14:09:01 PST 2012
I found this one [1], if I remember correctly this is the one you have in the PBE cool website right? I'm thinking more like the GNS icon you put in the right-bottom corner, but this should appear once I choose each WMS. I'm using the good GeoExt 1.0 with the old, good friend Ext 3.4, so changing to 4.1 is not a good idea =). I haven't, I will take a deep look at it, thanks Phil.
[1] http://geoprisma.org/samples/geoextux/layertreebuilder/index.php
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
> Date: Wed, 28 Nov 2012 10:58:40 +1300
> From: p.scadden at gns.cri.nz
> CC: openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] legend "floating" over map - Calling Alexandre Dube!
> Which geoext version are you using? That one should work for 1.0. There
> is a working one for Extjs 4.1 but I cant remember exactly how I got it.
> Investigate his sandbox more closely?
> Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121127/eedc1a7b/attachment.html>
