[OpenLayers-Users] Use WFS Information
vGIS valentino1s73s at gmx.net
Thu Sep 20 04:07:34 PDT 2012
Thanks Bart!
Kind regards,
vGIS
Bart van den Eijnden wrote
> If you are using an OpenLayers Format to parse this, then
> feature.attributes.typ and feature.attributes.tst
> Best regards,
> Bart
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> On Sep 20, 2012, at 12:50 PM, vGIS <
> valentino1s73s@
> > wrote:
>> A WFS-Call returns the following XML per feature:
> <gml:featureMembers>
> <topp:poly gml:id="poly.20">
> <topp:geom>
> <gml:Polygon srsDimension="2"
>  srsName="http://www.opengis.net/gml/srs/epsg.xml#31468">
> <gml:exterior>
> <gml:LinearRing srsDimension="2">
> <gml:posList>
> 4356401.9816206 5513006.8751176 4355269.8991122
>> 5511558.8626068 4357639.3741298 5510874.3476018 4358113.2691333
>> 5512506.6526139 4356401.9816206 5513006.8751176
> </gml:posList>
> </gml:LinearRing>
> </gml:exterior>
> </gml:Polygon>
> </topp:geom>
> <topp:typ>
> 1
> </topp:typ>
> <topp:tst>
> test
> </topp:tst>
> </topp:poly>
>> Now, I'd like to use the bold marked information. How can feature
>> attributes
>> (not only id/fid/geom) be called?
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Use-WFS-Information-tp5003197.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Users at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
> Users at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/Use-WFS-Information-tp5003197p5003201.html
