[OpenLayers-Users] OpenLayers.Control.ModifyFeature will not delete vertex ...
John Harris
jibs at fsmail.net
Mon Aug 5 17:59:11 PDT 2013
Andreas,
Thank you for your reply ! First can you tell me how can I tell which
version of OpenLayers I am using ? In my script I use and assume that this
will access the latest version ?
Secondly, I think I am right that if the ModifyFeature control is configured
with {standalone: true} then I can select a feature into this control by
using its SelectFeature method but not by clicking over the feature on the
map ? But once a feature is selected by either means does the control see
any difference - ie. does it have any recollection of how the feature was
selected ?
Thanks and regards
John
View this message in context: http://osgeo-org.1560.x6.nabble.com/OpenLayers-Control-ModifyFeature-will-not-delete-vertex-tp5069993p5070938.html
