[OpenLayers-Users] Mathematical description of the cluster algorithm?
Samuel Leach
samuel.leach at gmail.com
Thu Aug 15 01:26:28 PDT 2013
Hello,
This is my first post to the list - thanks for your patience.
I've being trying to find out the answer to the question, what is the (name
of) the clustering algorithm used in openlayers, and is there a
mathematical description posted somewhere?
A bit of research has turned up the source code,
https://github.com/openlayers/openlayers/blob/master/lib/OpenLayers/Strategy/Cluster.j<https://github.com/openlayers/openlayers/blob/master/lib/OpenLayers/Strategy/Cluster.js>
s
an example of varying the distance and threshold parameters,
http://openlayers.org/dev/examples/strategy-cluster-threshold.html
and the method is discussed in Ch. 4 of OpenLayers Cookbook 2012.
However, I'm still not sure about the answer to the above question.
Could someone knowledgable chime in?
Thank you
Sam Leach
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130815/e662ede2/attachment-0001.html>
