[OpenLayers-Users] Mathematical description of the cluster algorithm?
Martin Davis
mtnclimb at gmail.com
Thu Aug 15 14:42:16 PDT 2013
You may not find a "mathematical description" of the clustering algorithm
that OpenLayes uses. It's a simple (and somewhat brute force) iterative
algorithm, whereas most "mathematical" clustering algorithms are more
concerned with computing a clustering that provides some useful global
statistical properties.
On Thu, Aug 15, 2013 at 1:26 AM, Samuel Leach <samuel.leach at gmail.com>wrote:
> Hello,
> This is my first post to the list - thanks for your patience.
> I've being trying to find out the answer to the question, what is the
> (name of) the clustering algorithm used in openlayers, and is there a
> mathematical description posted somewhere?
> A bit of research has turned up the source code,
> https://github.com/openlayers/openlayers/blob/master/lib/OpenLayers/Strategy/Cluster.j<https://github.com/openlayers/openlayers/blob/master/lib/OpenLayers/Strategy/Cluster.js>
> s
> an example of varying the distance and threshold parameters,
> http://openlayers.org/dev/examples/strategy-cluster-threshold.html
> and the method is discussed in Ch. 4 of OpenLayers Cookbook 2012.
> However, I'm still not sure about the answer to the above question.
> Could someone knowledgable chime in?
> Thank you
> Sam Leach
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130815/b36ae2be/attachment.html>
