[OpenLayers-Users] Canvas issue when using externalGraphic
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Sun Aug 18 16:03:45 PDT 2013
Hi Alexandre (second time),
I've had it in front and did not see it, the "onLoad" is the PROBLEM!
I think I can prepare a Canvas.js patch...
Xavier
Xavier Mamano (jorix) wrote
> Hi Alexandre,
>> but it would still be nice to nail the cause of the issue.
> See: http://jsfiddle.net/jorix/X77cw/
> (after returning from a week in the mountains offline... I extracted the
> code from Canvas.js to set an example of the problem without using
> OpenLayers)
> Try "d1" or "d2", so operates properly.
> But "d1 & d2" not!, the result should be as "d2" (not as d1+d2) :(
> Regards,
> Xavier
> Alexandre Dubé wrote
>> Xavier,
>> You're right. Thanks for sharing your solutions. I think using your
>> workaround (locking the renderer on unselectAll) combined with a
>> tolerance of 0 could do the trick for me, but it would still be nice to
>> I'll update my example.
>> Thanks again,
>> Alexandre
>> On 13-08-09 04:46 PM, Xavier Mamano (jorix) wrote:
>>> Hi
>>> But the problem remains when the clickout has a little drag before (less
>>> than 4 pixels --see clickTolerance on OpenLayers.Handler.Feature--)
>>> Try select the features, and unselect by: mousedown + mousemove (less
>>> than 4
>>> pixels) + mouseup. Oops!
>>> Seems that "this.canvas.clearRect (0, 0, width, height);" on
>>> Canvas.redraw
>>> does not act a second time while the js code is still running.
>>> Xavier
>>>> Hi,
>>>> I tried your workaround...
>>>> It works on Chrome but not on FF.
>>>> And tried this:
>>>> select.unselectAll = function(options) {
>>>> vectors.renderer.locked = true;
>>>> OpenLayers.Control.SelectFeature.prototype.unselectAll.apply(
>>>> this, arguments);
>>>> vectors.renderer.locked = false;
>>>> vectors.moveTo(null, true, false); // to force a
>>>> vectors.redraw();
>>>> It works on FF & Chrome.
>>>> Xavier
>>>>> Hi,
>>>>> Here's a pretty dirty workaround:
>>>>> http://dev5.mapgears.com/openlayers/2.12-canvas-issue/examples/canvas-issue-workaround.html?renderer=Canvas
>>>>> In summary, I redraw the layer after features were unselected.
>>>>> I'm still not sure what's the cause of the issue, but I noticed
>>>>> that
>>>>> when calling the unselectAll method of the select control, each
>>>>> feature
>>>>> are drawn (using layer.drawFeature method) separately, resulting in
>>>>> redrawing the layer X times for each feature that were unselected.
>>>>> Maybe if the renderer was locked while unselecting all these it could
>>>>> do
>>>>> the trick.
>>>>> Please, let me know if this should deserve an Issue opened.
>>>>> Alexandre
>>>>> On 13-08-07 01:14 PM, Alexandre Dubé wrote:
>>>>>> Thanks to everyone who tried the example. I'll try to can come up
>>>>>> with a fix or a workaround asap.
>>>>>> Alexandre
>>>>>> On 13-08-07 11:02 AM, Xavier Mamano (jorix) wrote:
>>>>>>> Hi,
>>>>>>> I can confirm seeing this using Windows Vista on Chrome, FF, IE9 and
>>>>>>> Opera
>>>>>>> and olso usign Ubuntu on Chome and FF.
>>>>>>> (using your canvas-issue.html)
>>>>>>> Xavier Mamano
>>>>>>>> Hi,
>>>>>>>> I have an issue when I use Canvas as vector renderer in
>>>>>>>> addition
>>>>>>>> to
>>>>>>>> having externalGraphic properties. I noticed the issue using
>>>>>>>> OpenLayers
>>>>>>>> 2.12, 2.13 and 2.13.1, with the 3 browsers I tested: Chrome,
>>>>>>>> Firefox
>>>>>>>> and
>>>>>>>> IE9.
>>>>>>>> I made a small demo to show the issue 'live':
>>>>>>>> http://dev5.mapgears.com/openlayers/2.12-canvas-issue/examples/canvas-issue.html?renderer=Canvas
>>>>>>>> Before trying to look deeper at the code to see what's going
>>>>>>>> on
>>>>>>>> wrong, I wonder if anyone already hit this same issue and came up
>>>>>>>> with a
>>>>>>>> fix / solution / workaround.
>>>>>>>> Many thanks,
>>>>>>>> Alexandre
>>>>>>>> P.S. The example's html file can be downloaded and added to any
>>>>>>>> local
>>>>>>>> examples folder in order to test it locally with different versions
>>>>>>>> of
>>>>>>>> OpenLayers, i.e. the images and externalGraphic links are absolute,
>>>>>>>> not
>>>>>>>> relative.
>>>>>>>> Alexandre Dubé
>>>>>>>> Mapgears
>>>>>>>> www.mapgears.com
>>>>>>>> _______________________________________________
>>>>>>>> Users mailing list
>>>>>>>> Users at .osgeo
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>>>>> View this message in context:
>>>>>>> http://osgeo-org.1560.x6.nabble.com/Canvas-issue-when-using-externalGraphic-tp5071099p5071319.html
>>>>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>>>>> Users mailing list
>>>>> Users at .osgeo
>>>>> Alexandre Dubé
>>>>> Mapgears
>>>>> www.mapgears.com
>>>>> Users mailing list
>>>>> Users at .osgeo
>>> http://osgeo-org.1560.x6.nabble.com/Canvas-issue-when-using-externalGraphic-tp5071099p5071801.html
>>> Users mailing list
>> Users at .osgeo
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Users mailing list
>> Users at .osgeo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Canvas-issue-when-using-externalGraphic-tp5071099p5073053.html
