[OpenLayers-Users] Canvas issue when using externalGraphic
Alexandre Dubé
adube at mapgears.com
Mon Aug 19 06:00:23 PDT 2013
Xavier,
Thank you very much for your efforts. I'm looking forward to see
your patch as I don't understand what the issue with the onLoad is.
Thanks again,
Alexandre
On 13-08-18 07:03 PM, Xavier Mamano (jorix) wrote:
> Hi Alexandre (second time),
> I've had it in front and did not see it, the "onLoad" is the PROBLEM!
> I think I can prepare a Canvas.js patch...
> Xavier
>> Hi Alexandre,
>>> but it would still be nice to nail the cause of the issue.
>> See: http://jsfiddle.net/jorix/X77cw/
>> (after returning from a week in the mountains offline... I extracted the
>> code from Canvas.js to set an example of the problem without using
>> OpenLayers)
>> Try "d1" or "d2", so operates properly.
>> But "d1 & d2" not!, the result should be as "d2" (not as d1+d2) :(
>> Regards,
>> Xavier
>> Alexandre Dubé wrote
>>> Xavier,
>>> You're right. Thanks for sharing your solutions. I think using your
>>> workaround (locking the renderer on unselectAll) combined with a
>>> tolerance of 0 could do the trick for me, but it would still be nice to
>>> I'll update my example.
>>> Thanks again,
>>> Alexandre
>>> On 13-08-09 04:46 PM, Xavier Mamano (jorix) wrote:
>>>> Hi
>>>> But the problem remains when the clickout has a little drag before (less
>>>> than 4 pixels --see clickTolerance on OpenLayers.Handler.Feature--)
>>>> Try select the features, and unselect by: mousedown + mousemove (less
>>>> than 4
>>>> pixels) + mouseup. Oops!
>>>> Seems that "this.canvas.clearRect (0, 0, width, height);" on
>>>> Canvas.redraw
>>>> does not act a second time while the js code is still running.
>>>> Xavier
>>>>> Hi,
>>>>> I tried your workaround...
>>>>> It works on Chrome but not on FF.
>>>>> And tried this:
>>>>> select.unselectAll = function(options) {
>>>>> vectors.renderer.locked = true;
>>>>> OpenLayers.Control.SelectFeature.prototype.unselectAll.apply(
>>>>> this, arguments);
>>>>> vectors.renderer.locked = false;
>>>>> vectors.moveTo(null, true, false); // to force a
>>>>> vectors.redraw();
>>>>> It works on FF & Chrome.
>>>>> Xavier
>>>>>> Hi,
>>>>>> Here's a pretty dirty workaround:
>>>>>> http://dev5.mapgears.com/openlayers/2.12-canvas-issue/examples/canvas-issue-workaround.html?renderer=Canvas
>>>>>> In summary, I redraw the layer after features were unselected.
>>>>>> I'm still not sure what's the cause of the issue, but I noticed
>>>>>> that
>>>>>> when calling the unselectAll method of the select control, each
>>>>>> feature
>>>>>> are drawn (using layer.drawFeature method) separately, resulting in
>>>>>> redrawing the layer X times for each feature that were unselected.
>>>>>> Maybe if the renderer was locked while unselecting all these it could
>>>>>> do
>>>>>> the trick.
>>>>>> Please, let me know if this should deserve an Issue opened.
>>>>>> Alexandre
>>>>>> On 13-08-07 01:14 PM, Alexandre Dubé wrote:
>>>>>>> Thanks to everyone who tried the example. I'll try to can come up
>>>>>>> with a fix or a workaround asap.
>>>>>>> Alexandre
>>>>>>> On 13-08-07 11:02 AM, Xavier Mamano (jorix) wrote:
>>>>>>>> Hi,
>>>>>>>> I can confirm seeing this using Windows Vista on Chrome, FF, IE9 and
>>>>>>>> Opera
>>>>>>>> and olso usign Ubuntu on Chome and FF.
>>>>>>>> (using your canvas-issue.html)
>>>>>>>> Xavier Mamano
>>>>>>>>> Hi,
>>>>>>>>> I have an issue when I use Canvas as vector renderer in
>>>>>>>>> addition
>>>>>>>>> to
>>>>>>>>> having externalGraphic properties. I noticed the issue using
>>>>>>>>> OpenLayers
>>>>>>>>> 2.12, 2.13 and 2.13.1, with the 3 browsers I tested: Chrome,
>>>>>>>>> Firefox
>>>>>>>>> and
>>>>>>>>> IE9.
>>>>>>>>> I made a small demo to show the issue 'live':
>>>>>>>>> http://dev5.mapgears.com/openlayers/2.12-canvas-issue/examples/canvas-issue.html?renderer=Canvas
>>>>>>>>> Before trying to look deeper at the code to see what's going
>>>>>>>>> on
>>>>>>>>> wrong, I wonder if anyone already hit this same issue and came up
>>>>>>>>> with a
>>>>>>>>> fix / solution / workaround.
>>>>>>>>> Many thanks,
>>>>>>>>> Alexandre
>>>>>>>>> P.S. The example's html file can be downloaded and added to any
>>>>>>>>> local
>>>>>>>>> examples folder in order to test it locally with different versions
>>>>>>>>> of
>>>>>>>>> OpenLayers, i.e. the images and externalGraphic links are absolute,
>>>>>>>>> not
>>>>>>>>> relative.
>>>>>>>>> Alexandre Dubé
>>>>>>>>> Mapgears
>>>>>>>>> www.mapgears.com
>>>>>>>>> _______________________________________________
>>>>>>>>> Users mailing list
>>>>>>>>> Users at .osgeo
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>>>>>> View this message in context:
>>>>>>>> http://osgeo-org.1560.x6.nabble.com/Canvas-issue-when-using-externalGraphic-tp5071099p5071319.html
>>>>>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>>>>>> Users mailing list
>>>>>> Users at .osgeo
>>>>>> Alexandre Dubé
>>>>>> Mapgears
>>>>>> www.mapgears.com
>>>>>> Users mailing list
>>>>>> Users at .osgeo
>>>> http://osgeo-org.1560.x6.nabble.com/Canvas-issue-when-using-externalGraphic-tp5071099p5071801.html
>>>> Users mailing list
>>> Users at .osgeo
>>> Alexandre Dubé
>>> Mapgears
>>> www.mapgears.com
>>> Users mailing list
>>> Users at .osgeo
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Canvas-issue-when-using-externalGraphic-tp5071099p5073053.html
> Users mailing list
> Users at lists.osgeo.org
Alexandre Dubé
Mapgears
www.mapgears.com
