[OpenLayers-Users] enable Deletefeature in multiple layer
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Wed Aug 21 04:57:06 PDT 2013
Maybe he can help you this non-standard code: "ModifyFeature-tools.js"
Could work on multilayer to modify/delete features.
See examples:
http://jorix.github.io/OL-Ragbag/examples/modify-feature-multilayer.html
(selection own, so preferred. uses pieces of "featureclick" mentioned by
"m1k3ry4n".)
http://jorix.github.io/OL-Ragbag/examples/modify-feature-selectFeature.html
(selection by selectFeature)
To allows modify&delete use:
var modify = new OpenLayers.Control.ModifyFeature(null, {
layers:[bottomLayer, middleLayer, topLayer],
mode: OpenLayers.Control.ModifyFeature.VERTICES |
OpenLayers.Control.ModifyFeature.DELETE
NOTE: ModifyFeature-tools.js is API compatible with OL-ModifyFeature.
Regards,
summer7310 wrote
> Hi,all
> I have a problem about Delete Control. In my map i have 3 layers and i
> would like to enable the Deletefeature in each layer at the same time,but
> the DeleteFeature control can only be used with a single layer at any
> given time. and it seems that just the last delete control can work.
> Anyone has a suggestion how to modify multiple layer?
> Thanks in advance for any help.
View this message in context: http://osgeo-org.1560.x6.nabble.com/enable-Deletefeature-in-multiple-layer-tp5072687p5073545.html
