[OpenLayers-Users] change tms layer does not change map view
Juan Abreu
juanabreu at hotmail.com
Sat Aug 31 01:48:27 PDT 2013
I have a TMS layer that I'm using as my map, i have set it up so that
users can change the map
however changing the layer does not update the map view until i hit the
zoom in button or the zoom out button. how can i refresh the map view to
show the newly added layer?
here is a quick code sample. i tried layer.redraw() without any
solution. does someone have any other ideas.on a desperate i just try setting the map div html to "" and it
finally updated the layer. is this the proper way to do this?
[code sample below]
function initMAP() {
var mapBounds = new OpenLayers.Bounds(bounds[0], bounds[1], bounds[2], bounds[3]);
var mapMinZoom = 0;
var mapMaxZoom = 3;
// avoid pink tiles
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
OpenLayers.Util.onImageLoadErrorColor = "transparent";
var options = {
theme: null,
controls: [
new OpenLayers.Control.Navigation({
dragPanOptions: {
// enableKinetic: true
new OpenLayers.Control.Attribution(),
new OpenLayers.Control.Zoom()
maxExtent: new OpenLayers.Bounds(bounds[0], bounds[1], bounds[2], bounds[3]),
maxResolution: 4,
numZoomLevels: 3
map = new OpenLayers.Map('map', options);
layer = new OpenLayers.Layer.TMS("TMS", "http://mymapserver.com/MAP2/", { 'type': 'png', 'getURL': get_my_url });
map.addLayer(layer);
layer.redraw({ force: true });
map.zoomToExtent(mapBounds);
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130831/5529d470/attachment.html>
