[OpenLayers-Users] Google background layers offset with overlay layers
b.j.kobben at utwente.nl
Wed Feb 6 06:20:35 PST 2013
Your URL
http://data.glifwc.org/manoomin.harvest.info/
results in a 404-Not Found error...
On 05-02-13 23:32, "Dara Olson" <dolson at glifwc.org> wrote:
>Greetings.
>We have an Open Layer map that uses Google background layers. We overlay
>other WMS and a text file with points and when the map is loaded Google
>Maps seems to be slightly off to the east. When you turn on Google
>Satellite layer
> then the map bounces back into the correct location lining up with the
>overlay layers correctly. You can turn Google Streets back on and it
>lines up correctly. This application was working correctly without the
>offset up until around 3-4 months ago (October-November)
> when this started happening.
>Any suggestions on why this may be happening? Or points in the correct
>direction to fix? Below is the map.js and a link to the website.
><http://maps.glifwc.org/manoomin.harvest.info/>
>var map;
> function init(){
> // Define Map Controls
> var options = {
> maxExtent: new OpenLayers.Bounds(-20037508.34,
>-20037508.34, 20037508.34, 20037508.34),
> controls: [new OpenLayers.Control.Navigation(), new
>OpenLayers.Control.PanZoomBar(), new OpenLayers.Control.LayerSwitcher()]
> map = new OpenLayers.Map('map', options);
> //map = new OpenLayers.Map('map');
> // Define Base Layers
> var gmap = new OpenLayers.Layer.Google(
> "Google Streets", // the default
> {numZoomLevels: 20}
> var gsat = new OpenLayers.Layer.Google(
> "Google Satellite",
> {type: google.maps.MapTypeId.SATELLITE,
>numZoomLevels: 22}
> var ghyb = new OpenLayers.Layer.Google(
> "Google Hybrid",
> {type: google.maps.MapTypeId.HYBRID, numZoomLevels:
>20}
> var gphy = new OpenLayers.Layer.Google(
> "Google Physical",
> {type: google.maps.MapTypeId.TERRAIN}
> // Define Overlay Layers
> var layer = new OpenLayers.Layer.Vector("Date-regulated
>Manoomin Lakes", {
> strategies: [new OpenLayers.Strategy.BBOX({resFactor:
>1.1})],
> protocol: new OpenLayers.Protocol.HTTP({
> url: "points/points.txt",
> format: new OpenLayers.Format.Text()
> //Projection = WGS84 (4326)
> var manoomin = new OpenLayers.Layer.WMS("All Manoomin
>Waters",
> "http://maps.glifwc.org/glifwc_wms.php?",
> {'layers':
>'manoomin_waterbodies,manoomin_lines,manoomin_points', transparent: true,
>format: 'image/gif'},
> {isBaseLayer: false, visibility: true}
> // Add Layers To Map
> map.addLayers([gmap, gsat, ghyb, gphy, layer, manoomin]);
> //map.zoomToMaxExtent();
> //Set Initial Extent
> map.setCenter(new OpenLayers.LonLat(-90, 45.5).transform(
> new OpenLayers.Projection("EPSG:4326"),
> map.getProjectionObject()
> ), 6);
> //****** Select And Display Feature Info ******//
> // Interaction; not needed for initial display.
> selectControl = new
>OpenLayers.Control.SelectFeature(layer);
> map.addControl(selectControl);
> selectControl.activate();
> layer.events.on({
> 'featureselected': onFeatureSelect,
> 'featureunselected': onFeatureUnselect
> // Needed only for interaction, not for the display.
> function onPopupClose(evt) {
> // 'this' is the popup.
> var feature = this.feature;
> if (feature.layer) { // The feature is not destroyed
> selectControl.unselect(feature);
> } else { // After "moveend" or "refresh" events on POIs
>layer all
> // features have been destroyed by the
>Strategy.BBOX
> this.destroy();
> function onFeatureSelect(evt) {
> feature = evt.feature;
> popup = new OpenLayers.Popup.FramedCloud("featurePopup",
>feature.geometry.getBounds().getCenterLonLat(),
> new OpenLayers.Size(100,100),
> "<h2>"+feature.attributes.title
>+ "</h2>" +
> feature.attributes.description,
> null, true, onPopupClose);
> feature.popup = popup;
> popup.feature = feature;
> map.addPopup(popup, true);
> function onFeatureUnselect(evt) {
> if (feature.popup) {
> popup.feature = null;
> map.removePopup(feature.popup);
> feature.popup.destroy();
> feature.popup = null;
>Any help would be greatly appreciated.
>Dara
