[OpenLayers-Users] Label mis-align with IE9
Alexandre Dubé
adube at mapgears.com
Wed Feb 6 06:30:52 PST 2013
Hi Andreas,
I just hit the same issue described here in one of my app. I made a
small example to clearly show the issue with the SVG renderer in IE9 :
http://dev5.mapgears.com/tests/openlayers-ie9-label-shift/
Canvas is fine in IE9. VML works fine for IE8 and 7. Has anyone
found a solution for this yet ? Any workaround ?
Regards,
Alexandre
On 12-07-25 03:38 AM, Andreas Hocevar wrote:
> I just tried myself and noticed a slight shift towards the bottom in
> IE9. Can you confirm that this is what you're seeing, or is there
> something else/different?
> Andreas.
> On Tue, Jul 10, 2012 at 7:35 PM, Lak Krishnan
> <lakshmanan.krishnan at mecklenburgcountync.gov> wrote:
>> "vector feature with text" example still shows with the labels shifted in
>> IE9. Is there anything else that need to be done to eliminate the vector
>> label misalignment problem? I have the same problem in one of my
>> applications. I have the below in my HTML document and it has not helped the
>> cause at all.
>> <!DOCTYPE html>
>> <html lang="en">
>> -lak
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/Label-mis-align-with-IE9-tp3916849p4987384.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Alexandre Dubé
Mapgears
www.mapgears.com
