[OpenLayers-Users] Label mis-align with IE9
Andreas Hocevar
ahocevar at opengeo.org
Thu Feb 7 01:32:26 PST 2013
Hey Alexandre,
thanks for putting together this example. I guess the only workaround
other than using the Canvas renderer is to do a browser check in the
SVG renderer (the issue also persists with IE10) and apply an offset
to labels. I guess it will be fun to find out what offset is required.
Is it linear with the font size, is it fixed, ...?
Andreas.
On Wed, Feb 6, 2013 at 3:30 PM, Alexandre Dubé <adube at mapgears.com> wrote:
> Hi Andreas,
> I just hit the same issue described here in one of my app. I made a small
> example to clearly show the issue with the SVG renderer in IE9 :
> http://dev5.mapgears.com/tests/openlayers-ie9-label-shift/
> Canvas is fine in IE9. VML works fine for IE8 and 7. Has anyone found a
> solution for this yet ? Any workaround ?
> Regards,
> Alexandre
> On 12-07-25 03:38 AM, Andreas Hocevar wrote:
>> I just tried myself and noticed a slight shift towards the bottom in
>> IE9. Can you confirm that this is what you're seeing, or is there
>> something else/different?
>> Andreas.
>> On Tue, Jul 10, 2012 at 7:35 PM, Lak Krishnan
>> <lakshmanan.krishnan at mecklenburgcountync.gov> wrote:
>>> "vector feature with text" example still shows with the labels shifted in
>>> IE9. Is there anything else that need to be done to eliminate the vector
>>> label misalignment problem? I have the same problem in one of my
>>> applications. I have the below in my HTML document and it has not helped
>>> the
>>> cause at all.
>>> <!DOCTYPE html>
>>> <html lang="en">
>>> -lak
>>> View this message in context:
>>> http://osgeo-org.1560.n6.nabble.com/Label-mis-align-with-IE9-tp3916849p4987384.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
