[OpenLayers-Users] SelectFeature with multi-vector-layers
Meine Toonen
meinetoonen at b3partners.nl
Wed Feb 13 02:20:43 PST 2013
Try to pass the instantiated object into the array:
this.selectCtrl = new OpenLayers.Control.SelectFeature([this.vectorLayer, this.rseqVectorLayer],{});
Here this.vectorLayer and this.rseqVectorLayer are the instantiated objects of OpenLayers.Layer.Vector.
Met vriendelijke groet,
Meine Toonen
B3Partners BV
Tel: 030 214 2083
_____
To: openlayers-users at lists.osgeo.org
Sent: Wed, 13 Feb 2013 10:51:43 +0100
Subject: [OpenLayers-Users] SelectFeature with multi-vector-layers
Hi OL-users,
I'm a little bit frustrated. Reason is that I try now for some days to
persuade the OpenLayers.Control.SelectFeature to work with an array of
two vector layers. With one everything is fine. But when I put this
layer name into []-brackets I'm not able to select the features of this
vector layer anymore. Not to speak of two layer array. I've already
compared my script with the example 'select-feature-multilyer.html'. And
I found no fault.
Therefore my question to you. Does someone know if there's a known
problem in combination with OL 2.12?
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130213/84b7d11a/attachment.html>
