[OpenLayers-Users] [Idea] Declaratively defining an OL map
Erdal Karaca
erdal.karaca.de at gmail.com
Wed Feb 27 23:58:54 PST 2013
Yes, that is my intention, too: being able to serialize/deserialize a
map configuration.
Is your project open source?
I have started to work in that direction: defining a schema (currently
no XSD, but an eclipse ecore model), so I can define the map
configuration in Java, then, generate JS code from it and evaluate it
in the browser:
https://github.com/erdalkaraca/geoff
2013/2/27 Phil Scadden <p.scadden at gns.cri.nz>:
> I create maps pretty much in the style, where I load the "declarations" as a
> json object, and then have the code translates this into the map and layer
> properties. I have a webapp for creating the map and the behaviours you want
> on the map and in interactions with the layer and it saves the config as
> this json file.
> Notice: This email and any attachments are confidential.
> If received in error please destroy and immediately notify us.
> Do not copy or disclose the contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
