[OpenLayers-Users] Two displayProjections on a map
Bart van den Eijnden
bartvde at opengeo.org
Wed Jan 9 04:43:43 PST 2013
Hi Jan,
did you try using two MousePosition controls?
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Jan 9, 2013, at 1:40 PM, Jan Hartmann <j.l.h.hartmann at uva.nl> wrote:
> Is it possible to have tow displayprojections on a map? I would like to show the actual mouse position both in WGS84 latlon (epsg:4326) and in the projection of the map I am working on. Changing the projection in the Javascript file and starting the application anew does the trick, but I would like to see both coordinate pairs at the same time. Is there a trick to do this?
> Jan
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130109/5d9eb3c5/attachment.html>
