[OpenLayers-Users] Two displayProjections on a map
Jan Hartmann j.l.h.hartmann at uva.nl
Wed Jan 9 05:39:01 PST 2013
Works like a charm. Thanks Bart
On 1/9/2013 2:18 PM, Bart van den Eijnden wrote:
> Hi Jan,
> sure, just add displayClass to your Control definitions and make sure
> they differ:
>      * Property: displayClass
>      * {string}  This property is used for CSS related to the drawing
> of the
>      * Control.
>     displayClass: "",
> Best regards,
> Bart
> OpenGeo - http://opengeo.org <http://opengeo.org/>
> Expert service straight from the developers.
> On Jan 9, 2013, at 2:12 PM, Jan Hartmann <j.l.h.hartmann at uva.nl
> <mailto:j.l.h.hartmann at uva.nl>> wrote:
>> Hi Bart,
>> I tried it, and I guess it works, but the two controls are displayed
>> one over the other, and I see only the one last defined. There is a
>> way to position the Mouseposition control by css:
>> <style>
>> .olControlMousePosition {
>>     right 10;use
>>     top:0;
>>     etc
>> but that changes all MousePosition controls the same way. Is there a
>> way to give an id to a control, so I could use:
>> #olMousePosition1 {
>> #olMousePosition2 {
>> Jan
>> On 1/9/2013 1:43 PM, Bart van den Eijnden wrote:
>>> Hi Jan,
>>> did you try using two MousePosition controls?
>>> Best regards,
>>> Bart
>>> On Jan 9, 2013, at 1:40 PM, Jan Hartmann <j.l.h.hartmann at uva.nl
>>>> Is it possible to have tow displayprojections on a map? I would
>>>> like to show the actual mouse position both in WGS84 latlon
>>>> (epsg:4326) and in the projection of the map I am working on.
>>>> Changing the projection in the Javascript file and starting the
>>>> application anew does the trick, but I would like to see both
>>>> coordinate pairs at the same time. Is there a trick to do this?
>>>> Jan
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130109/b46b97e0/attachment-0001.html>
