[OpenLayers-Users] Two displayProjections on a map
Bart van den Eijnden
bartvde at opengeo.org
Wed Jan 9 05:18:04 PST 2013
Hi Jan,
sure, just add displayClass to your Control definitions and make sure they differ:
* Property: displayClass
* {string} This property is used for CSS related to the drawing of the
* Control.
displayClass: "",
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Jan 9, 2013, at 2:12 PM, Jan Hartmann <j.l.h.hartmann at uva.nl> wrote:
> Hi Bart,
> I tried it, and I guess it works, but the two controls are displayed one over the other, and I see only the one last defined. There is a way to position the Mouseposition control by css:
> <style>
> .olControlMousePosition {
> right 10;use
> top:0;
> etc
> but that changes all MousePosition controls the same way. Is there a way to give an id to a control, so I could use:
> #olMousePosition1 {
> #olMousePosition2 {
> Jan
> On 1/9/2013 1:43 PM, Bart van den Eijnden wrote:
>> Hi Jan,
>> did you try using two MousePosition controls?
>> Best regards,
>> Bart
>> On Jan 9, 2013, at 1:40 PM, Jan Hartmann <j.l.h.hartmann at uva.nl> wrote:
>>> Is it possible to have tow displayprojections on a map? I would like to show the actual mouse position both in WGS84 latlon (epsg:4326) and in the projection of the map I am working on. Changing the projection in the Javascript file and starting the application anew does the trick, but I would like to see both coordinate pairs at the same time. Is there a trick to do this?
>>> Jan
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130109/97436912/attachment.html>
