[OpenLayers-Users] OpenLayers with 900913 projection and drupal OpenLayers module
Alexander Kocisky
alexander.kocisky at gmail.com
Thu Jan 10 14:22:32 PST 2013
Hi Stephen,
ok, i will check on the projCode, it might be only the structure for
holding that param. I've added "sphericalMercator: true" to the map options
and to the layer options but apparently nothing changed. I've tried to pass
it as a true value or as a "true" string. Here are the two objects:
The map: openlayers-map-cf0776af options are: {
"projection": {
"projCode": "EPSG:900913"
"displayProjection": {
"projCode": "EPSG:4326"
"maxExtent": {
"left": -20037508.34,
"bottom": -20037508.34,
"right": 20037508.34,
"top": 20037508.34
"units": "m",
"sphericalMercator": true,
"maxResolution": "auto",
"controls": [],
"theme": "/sites/all/modules/openlayers/themes/default_dark/style.css"
The layer is {
"my_wms_layer": {
"base_url": "
http://gis.site.org:8080/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=MyMap:my_layer
"params": {
"isBaseLayer": 0,
"buffer": 2,
"ratio": 1.5,
"singleTile": 0,
"sphericalMercator": 1,
"resolutions": [
156543.0339,
78271.51695,
39135.758475,
19567.8792375,
9783.93961875,
4891.969809375,
2445.9849046875,
1222.9924523438,
611.49622617188,
305.74811308594,
152.87405654297,
76.437028271484,
38.218514135742,
19.109257067871,
9.5546285339355,
4.7773142669678,
2.3886571334839,
1.1943285667419,
0.59716428337097
"projection": {
"maxextent": [
-20037508,
-20037508,
20037508,
20037508
"drupalID": "my_wms_layer",
"units": "m",
"maxExtent": {
"top": 20037508.34
I think i should look at why that bound box parameter is incorrect, please
let me know if you have any suggestions.
Thank you again so much!
Alex
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130110/91ca7514/attachment-0001.html>
