[OpenLayers-Users] Highlight Selected Feature
Meine Toonen
meinetoonen at b3partners.nl
Wed Jan 16 04:16:18 PST 2013
You have to define a select renderIntent with the wanted visuals for highlighting.
For example, at creating the vectorlayer:
var style = new OpenLayers.Style(
// the first argument is a base symbolizer
// all other symbolizers in rules will extend this one
graphicWidth: 21,
graphicHeight: 21,
graphicYOffset: -28, // shift graphic up 28 pixels
label: "${label}",
symbolizer: {
externalGraphic: "../../images/treeview/radio_rood.gif"
var selectstyle = new OpenLayers.Style(
graphicWidth: 31,
graphicHeight: 31,
label: "${label}",
symbolizer: {
this.vectorLayer = new OpenLayers.Layer.Vector("Points", {
styleMap: new OpenLayers.StyleMap( {
"default": style,
"select": selectstyle
And then (for example) use a selectfeaturecontrol for selecting the features (on
var select = new OpenLayers.Control.SelectFeature(this.vectorLayer, {hover: true});
this.map.addControl(select);
select.activate();
Met vriendelijke groet,
Meine Toonen
B3Partners BV
Tel: 030 214 2083
Jerome A. Wendell <jawendell at digitalmapping.com> , 15-1-2013 22:24:
I have a map where I have selected a feature by attribute, and then centered and zoomed to the feature using the following:
vectorlayer.events.register('loadend', vectorlayer, function () {
var selfeatures = vectorlayer.getFeaturesByAttribute("description","description");
map.setCenter(selfeatures[0].geometry.getCentroid());
map.zoomToExtent(selfeatures[0].geometry.getBounds());
I am having trouble getting the feature to highlight. My select control for the map uses a popup. Could this be the problem? Do I need a second control to highlight the feature?
Any suggestions are appreciated.
Thanks,
Jerome Wendell
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130116/991ceb9b/attachment-0001.html>
