[OpenLayers-Users] How to draw a arrow with openlayer?
Imran Rajjad
rajjad at gmail.com
Wed Jan 23 06:28:05 PST 2013
you can make a feature whose geometry is a GeometryCollection, this
collection can contain a line and a point grouped into one geometry then
you can use the below mentioned style to draw an arrow with your line
strokeColor: "#00688B",
fillColor: "#00688B",
fillOpacity : 1.0,
strokeWidth: 2,
strokeOpacity : 0.9,
pointRadius: 6,
graphicName :"triangle",
rotation :angle
remember to compute the angle before setting this .. you should be able to
calculate angle between start and end point of your line segment.. and also
the position of point geometry which will be drawn as triage with given
rotation angle..
Hope I got my point through..
regards,
Imran
On Wed, Jan 23, 2013 at 7:11 PM, 杨华杰 <yhjhoo at gmail.com> wrote:
> Hi Alexandre
> Thank you, I will try this.
> Regards,
> Hua Jie
> On Wed, Jan 23, 2013 at 10:01 PM, Alexandre Dubé <adube at mapgears.com>wrote:
>> Hi Hua Jie,
>> You could try to define your own arrow symbol. There's one defined
>> [here], see line 1 :
>> OpenLayers.Renderer.symbol.arrow = [0,2, 1,0, 2,2, 1,0, 0,2]
>> I haven't tried it, but it could do the trick.
>> HTH,
>> Alexandre
>> [here]
>> http://code.google.com/p/rep-olnet/source/browse/trunk/Direction.js?r=61
>> On 13-01-23 07:09 AM, 杨华杰 wrote:
>> Hi
>> As the title
>> I know how to draw a line, dot, polygon. But my customer need some
>> directions on the map
>> Regards,
>> Hua Jie
>> Users mailing listUsers at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Alexandre Dubé
>> Mapgearswww.mapgears.com
>> Users mailing list
> Users mailing list
I.R
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130123/44723f88/attachment-0001.html>
