[OpenLayers-Users] How to draw a arrow with openlayer?
杨华杰
yhjhoo at gmail.com
Wed Jan 23 18:01:08 PST 2013
Hi Imran
Thanks for your reply. I believe a lot people have the same questions. Why
this feature is not released.
Regards,
Hua Jie
On Wed, Jan 23, 2013 at 10:28 PM, Imran Rajjad <rajjad at gmail.com> wrote:
> Hi,
> you can make a feature whose geometry is a GeometryCollection, this
> collection can contain a line and a point grouped into one geometry then
> you can use the below mentioned style to draw an arrow with your line
> strokeColor: "#00688B",
> fillColor: "#00688B",
> fillOpacity : 1.0,
> strokeWidth: 2,
> strokeOpacity : 0.9,
> pointRadius: 6,
> graphicName :"triangle",
> rotation :angle
> remember to compute the angle before setting this .. you should be able to
> calculate angle between start and end point of your line segment.. and also
> the position of point geometry which will be drawn as triage with given
> rotation angle..
> Hope I got my point through..
> regards,
> Imran
> On Wed, Jan 23, 2013 at 7:11 PM, 杨华杰 <yhjhoo at gmail.com> wrote:
>> Hi Alexandre
>> Thank you, I will try this.
>> Regards,
>> Hua Jie
>> On Wed, Jan 23, 2013 at 10:01 PM, Alexandre Dubé <adube at mapgears.com>wrote:
>>> Hi Hua Jie,
>>> You could try to define your own arrow symbol. There's one defined
>>> [here], see line 1 :
>>> OpenLayers.Renderer.symbol.arrow = [0,2, 1,0, 2,2, 1,0, 0,2]
>>> I haven't tried it, but it could do the trick.
>>> HTH,
>>> Alexandre
>>> [here]
>>> http://code.google.com/p/rep-olnet/source/browse/trunk/Direction.js?r=61
>>> On 13-01-23 07:09 AM, 杨华杰 wrote:
>>> Hi
>>> As the title
>>> I know how to draw a line, dot, polygon. But my customer need some
>>> directions on the map
>>> Regards,
>>> Hua Jie
>>> Users mailing listUsers at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/openlayers-users
>>> Alexandre Dubé
>>> Mapgearswww.mapgears.com
>>> Users mailing list
>> Users mailing list
> I.R
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130124/236671d1/attachment.html>
