[OpenLayers-Users] how to save added collection in server side
杨华杰 yhjhoo at gmail.com
Wed Jan 30 21:43:57 PST 2013
Here is someone encounter the same problem a long time ago, but it was not
resolved.
http://osgeo-org.1560.n6.nabble.com/Geometry-Collection-gml-parsing-failed-td3790014.html
After I enabled the log, I got this: 2013-01-31 13:33:01,933 DEBUG
[org.geotools.xml] - Could not find declaration for: {
http://www.opengis.net/gml}GeometryCollection. Checking if containing type
declares a single particle.
On Thu, Jan 31, 2013 at 1:19 PM, 杨华杰 <yhjhoo at gmail.com> wrote:
> And how to "change the logging to GeoTools Developer logging", can you
> give me some guide. The log which I provide is getting from geoserver
> On Thu, Jan 31, 2013 at 1:17 PM, 杨华杰 <yhjhoo at gmail.com> wrote:
>> I checked the xml passed to geoserver, there is no suspect at all.
>> Here is it:
>> http://caas.sg/geoserver/wfs/DescribeFeatureType&version=1.1.0&typename=CAAS:feature"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>> <wfs:Insert>
>> <feature:feature xmlns:feature="http://caas.sg">
>> <feature:the_geom>
>> <gml:GeometryCollection xmlns:gml="http://www.opengis.net/gml"
>> srsName="EPSG:4326">
>> <gml:geometryMember>
>> <gml:Point srsName="EPSG:4326"><gml:pos>92 -12</gml:pos></gml:Point>
>> </gml:geometryMember>
>> <gml:pos>70 -12</gml:pos>
>> </gml:Point>
>> </gml:GeometryCollection>
>> </feature:the_geom>
>> <feature:mapid>2052525f-80da-4f6e-83c0-cc9b87bdf218</feature:mapid>
>> <feature:versionname>versionName</feature:versionname>
>> <feature:strokecolor>#EE9900</feature:strokecolor>
>> <feature:defaultstrokewidth>3</feature:defaultstrokewidth>
>> <feature:selectedstrokewidth>4</feature:selectedstrokewidth>
>> <feature:strokedashstyle>solid</feature:strokedashstyle>
>> <feature:fillcolor>#F8D699</feature:fillcolor>
>> <feature:geometrytype>arrow</feature:geometrytype>
>> </feature:feature>
>> </wfs:Insert>
>> </wfs:Transaction>
>> On Thu, Jan 31, 2013 at 1:13 PM, Matt Priour <mpriour at kestrelcomputer.com
>> > wrote:
>>> On 01/30/2013 10:16 PM, 杨华杰 wrote:
>>> org.geoserver.wfs.WFSException: Error performing insert:
>>> java.lang.String cannot be cast to com.vividsolutions.jts.geom.Geometry
>>> That line is the key to determining what went wrong. You have a string
>>> representation of a geometry that is unparsable by the WFS server. The
>>> error message doesn't give any more details than that unfortunately.
>>> However, since you are using Geoserver, if you have admin access to the
>>> server, you can change the logging to GeoTools Developer logging and get as
>>> much detail as possible. Just make sure and NEVER EVER leave the server in
>>> that logging mode in a production machine.
>>> Hope that helps
>>> Matt Priour
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130131/45666a72/attachment-0001.html>
