[OpenLayers-Users] OpenLayers.Filter.Function with property parameter ?
brking
brking at gmail.com
Wed Jul 10 05:59:58 PDT 2013
Thank you for the quick response. I actually have a couple of different
scenarios, but basically if the example below from the OGC 1.1 encoding spec
is possible I should be in good shape:
<Filter>
<PropertyIsEqualTo>
<Function name="SIN">
<PropertyName>DISPERSION_ANGLE</PropertyName>
</Function>
<Literal>1</Literal>
</PropertyIsEqualTo>
</Filter>
So what I need is a way to pass feature property values as parameters to
filter functions, and use the function output in comparisons, or combined
with logical filters if the function returns a boolean.
View this message in context: http://osgeo-org.1560.x6.nabble.com/OpenLayers-Filter-Function-with-property-parameter-tp5065405p5065416.html
