[OpenLayers-Users] OL 2.13 generate unused html tags for PanControl
Andreas Hocevar
ahocevar at opengeo.org
Mon Jul 15 00:00:23 PDT 2013
This is a known oddity of OpenLayers 2. The reason is that controls are
designed to have a UI, and what you're seeing is the UI container. It is
created even if it is not used.
Andreas.
On Mon, Jul 15, 2013 at 2:38 AM, maven apache <apachemaven0 at gmail.com>wrote:
> Hi:
> I am using OpenLayers 2.13, and I create a simple map with just one
> PanControl, however I found that the generated html tags contains some
> unused codes.
> This is the codes:
> this.map = new OpenLayers.Map(container, {
> "projection" : "EPSG:4490",
> "controls" : []
> this.controls = {};
> this.controls.drag = new OpenLayers.Control.Navigation({
> "dragPanOptions" : {
> "enableKinetic" : true
> this.controls.p = new OpenLayers.Control.PanPanel({});
> var cons = [ this.controls.drag, this.controls.p ];
> this.map.addControls(cons);
> And this is generated tags <http://snag.gy/FkGE2.jpg>.
> Note the tags inside the red rectangle, it seems that these tags are
> unused.
> Do I miss anything?
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130715/419a630c/attachment.html>
