[OpenLayers-Users] OL 2.13 generate unused html tags for PanControl
maven apache
apachemaven0 at gmail.com
Mon Jul 15 05:15:01 PDT 2013
But why the PanZoomBarControl does not generate the codes?
2013/7/15 Andreas Hocevar <ahocevar at opengeo.org>
> This is a known oddity of OpenLayers 2. The reason is that controls are
> designed to have a UI, and what you're seeing is the UI container. It is
> created even if it is not used.
> Andreas.
> On Mon, Jul 15, 2013 at 2:38 AM, maven apache <apachemaven0 at gmail.com>wrote:
>> Hi:
>> I am using OpenLayers 2.13, and I create a simple map with just one
>> PanControl, however I found that the generated html tags contains some
>> unused codes.
>> This is the codes:
>> this.map = new OpenLayers.Map(container, {
>> "projection" : "EPSG:4490",
>> "controls" : []
>> this.controls = {};
>> this.controls.drag = new OpenLayers.Control.Navigation({
>> "dragPanOptions" : {
>> "enableKinetic" : true
>> this.controls.p = new OpenLayers.Control.PanPanel({});
>> var cons = [ this.controls.drag, this.controls.p ];
>> this.map.addControls(cons);
>> And this is generated tags <http://snag.gy/FkGE2.jpg>.
>> Note the tags inside the red rectangle, it seems that these tags are
>> unused.
>> Do I miss anything?
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130715/407abdc4/attachment-0001.html>
