[OpenLayers-Users] FrameCloud in OpenLayers
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Sun Jul 28 11:01:53 PDT 2013
> ... `black` area is not draggable.
I use this:
var myCloudPopup = OpenLayers.Class(OpenLayers.Popup.FramedCloud, {
displayClass: 'olScrollable olPopup', // scroll wheel
registerEvents:function() { //
this.events = new OpenLayers.Events(this, this.contentDiv, null,
true);
// return; // this `return` allows pan the map across the popup
àrea,
// but is dangerous if the popup has
links ...
this.events.on({
"mousedown": this.onmousedown,
"mousemove": this.onmousemove,
"mouseup": this.onmouseup,
"click": this.onclick,
"mouseout": this.onmouseout,
"dblclick": this.ondblclick,
"touchstart": function(evt) {
OpenLayers.Event.stop(evt, true);
scope: this
and then to create a popup I use this:
var myPopup = new myCloudPopup(...);
Regards,
kkk wrote
> Hi:
> I created a
> FramedCloud<http://dev.openlayers.org/releases/OpenLayers-2.13.1/doc/apidocs/files/OpenLayers/Popup/FramedCloud-js.html>
> using
> OpenLayers, and I meet some problems during the dragging.
> Check
> this<https://www.diigo.com/item/p/prpopsbzbqdobqcrozbassddqa/aa26410570325361fc2b7ea93aa0b646>,the
> `black` area is not draggable, It will cause some bad experience for the
> user.
> Is there any idea to fix it?
> BTW, we have our own map source data and related service, now we want to
> create a map library for the end user like the `google map` or `bing map`.
> But it is hard to create a library from the bottom level. So we wonder if
> we can take some advantage of OpenLayers. If so, we have two choices:
> 1) make the openlayer as the underlayer.
> We create every component under our namespace like
> `com.xx.Map,com.xx.TileLayer,com.xx.Event`, then use OpenLayers to do the
> implement work..
> For example:
> com.xx.Map=function(xx){
> this.underlayer=new OpenLayers.Map({.....});
> 2) Extract the components we need from openLayers and modify them
> accordingly.
> Which is better?
> Users mailing list
> Users at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
View this message in context: http://osgeo-org.1560.x6.nabble.com/FrameCloud-in-OpenLayers-tp5068844p5069206.html
