[OpenLayers-Users] Accessing user defined data from a OpenLayers application
Raffaele Morelli
raffaele.morelli at gmail.com
Tue Jun 4 21:51:27 PDT 2013
2013/6/4 Phil Scadden <p.scadden at gns.cri.nz>
> In firebug (or chrome's developer tools), with the NET panel, find the
> request to load the layer. (It will be a call to the proxy.cgi). Look to
> see what its status is and what response was (if any). I would strongly
> suspect a proxy issue (as you obviously do as well). However, I am
> unfamiliar with using cgi and I know little about to configure or debug.
cgi scripts debug is send to apache access/error logs, so does proxy
/r
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130605/37617125/attachment.html>
