[OpenLayers-Users] Accessing user defined data from a OpenLayers application
Nipuni Perera
nipuni880917 at gmail.com
Wed Jun 5 10:23:15 PDT 2013
I have checked error logs, but it does not show any error. I got the
response below (inspect it via firebug) :
Status: 502 Bad GatewayContent-Type: text/plainThis proxy does not
allow you to access that location (api.flickr.com).
Thanks,
Nipuni
On Wed, Jun 5, 2013 at 10:21 AM, Raffaele Morelli <
raffaele.morelli at gmail.com> wrote:
> 2013/6/4 Phil Scadden <p.scadden at gns.cri.nz>
>> In firebug (or chrome's developer tools), with the NET panel, find the
>> request to load the layer. (It will be a call to the proxy.cgi). Look to
>> see what its status is and what response was (if any). I would strongly
>> suspect a proxy issue (as you obviously do as well). However, I am
>> unfamiliar with using cgi and I know little about to configure or debug.
> cgi scripts debug is send to apache access/error logs, so does proxy
> /r
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Nipuni Piyabasi Perera
Undergraduate
Department of Computer Science And Engineering
University of Moratuwa
Sri Lanka
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130605/2930d098/attachment.html>
