[OpenLayers-Users] WFS layer not visible
Nipuni Perera
nipuni880917 at gmail.com
Wed Jun 5 11:03:26 PDT 2013
The errors I got earlier were due to the version of my Python install.
Python 3.x have different syntax styles than the earlier version. So I
shift to an older version of Python. Now I have nor error messages in log
file. But I get an error in the firebug
RangeError: invalid array length
I got a valid XML response, but the WFS features are not visible due to
this error.
Thanks,
Nipuni
On Wed, Jun 5, 2013 at 9:35 PM, Nipuni Perera <nipuni880917 at gmail.com>wrote:
> Hi,
> This is what I got with error.log file:
> SyntaxError: invalid syntax\r, referer: http://localhost/temp/temp.html
> Premature end of script headers: proxy.cgi, referer:
> File "C:/Server/Apache22/htdocs/temp/proxy.cgi", line 45\r, referer:
> print "Status: 502 Bad Gateway"\r, referer:
> ^\r, referer: http://localhost/temp/temp.html
> Thanks,
> Nipuni
> On Wed, Jun 5, 2013 at 10:30 AM, Raffaele Morelli <
> raffaele.morelli at gmail.com> wrote:
>> 2013/6/5 Nipuni Perera <nipuni880917 at gmail.com>
>>> Hi,
>>> Yes I have Python installed and the first line of the proxy.cgi is
>>> #!C:/Python33/python.exe -u
>>> which points to the python.exe location.
>>> I have set the changes to httpd.conf file as described here<http://vijaysambhe.wordpress.com/2012/10/12/openlayers-cross-domain-configure-proxyhost-on-windows/>.
>>> I have reinstalled Python and the response change from the script to an
>>> error message. This is the response I received for the POST request:
>>> <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>500 Internal Server Error</title></head><body><h1>Internal Server Error</h1><p>The server encountered an internal error ormisconfiguration and was unable to completeyour request.</p><p>Please contact the server administrator, admin at example.com and inform them of the time the error occurred,and anything you might have done that may havecaused the error.</p><p>More information about this error may be availablein the server error log.</p></body></html>
>>> This is the same error message I get when I try to open the proxy.cgi from localhost.
>>> Thanks,
>>> Nipuni
>> You should have a look at apache error log, it's clearly a
>> misconfiguration in apache (error 500) and what you need for debug is there.
>> I would suggest to check directory and/or file permissions (ie. virtual
>> host configuration directives).
>> /r
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Nipuni Piyabasi Perera
> Undergraduate
> Department of Computer Science And Engineering
> University of Moratuwa
> Sri Lanka
Undergraduate
Sri Lanka
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130605/79100363/attachment.html>
