[OpenLayers-Users] WFS layer not visible
Nipuni Perera
nipuni880917 at gmail.com
Wed Jun 5 12:46:04 PDT 2013
Hi
I have deleted the parameter
version: "1.1.0"
from the WFS protocol
(OpenLayers.Protocol.WFS({version:"1.0.0" ...})) ,
and now it is fixed. WFS features I have requested are shown on the map.
Thanks,
Nipuni
On Wed, Jun 5, 2013 at 11:33 PM, Nipuni Perera <nipuni880917 at gmail.com>wrote:
> Hi,
> The errors I got earlier were due to the version of my Python install.
> Python 3.x have different syntax styles than the earlier version. So I
> shift to an older version of Python. Now I have nor error messages in log
> file. But I get an error in the firebug
> RangeError: invalid array length
> I got a valid XML response, but the WFS features are not visible due to
> this error.
> Thanks,
> Nipuni
> On Wed, Jun 5, 2013 at 9:35 PM, Nipuni Perera <nipuni880917 at gmail.com>wrote:
>> Hi,
>> This is what I got with error.log file:
>> SyntaxError: invalid syntax\r, referer: http://localhost/temp/temp.html
>> Premature end of script headers: proxy.cgi, referer:
>> File "C:/Server/Apache22/htdocs/temp/proxy.cgi", line 45\r, referer:
>> print "Status: 502 Bad Gateway"\r, referer:
>> ^\r, referer:
>> Thanks,
>> Nipuni
>> On Wed, Jun 5, 2013 at 10:30 AM, Raffaele Morelli <
>> raffaele.morelli at gmail.com> wrote:
>>> 2013/6/5 Nipuni Perera <nipuni880917 at gmail.com>
>>>> Hi,
>>>> Yes I have Python installed and the first line of the proxy.cgi is
>>>> #!C:/Python33/python.exe -u
>>>> which points to the python.exe location.
>>>> I have set the changes to httpd.conf file as described here<http://vijaysambhe.wordpress.com/2012/10/12/openlayers-cross-domain-configure-proxyhost-on-windows/>.
>>>> I have reinstalled Python and the response change from the script to an
>>>> error message. This is the response I received for the POST request:
>>>> <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>500 Internal Server Error</title></head><body><h1>Internal Server Error</h1><p>The server encountered an internal error ormisconfiguration and was unable to completeyour request.</p><p>Please contact the server administrator, admin at example.com and inform them of the time the error occurred,and anything you might have done that may havecaused the error.</p><p>More information about this error may be availablein the server error log.</p></body></html>
>>>> This is the same error message I get when I try to open the proxy.cgi from localhost.
>>>> Thanks,
>>>> Nipuni
>>> You should have a look at apache error log, it's clearly a
>>> misconfiguration in apache (error 500) and what you need for debug is there.
>>> I would suggest to check directory and/or file permissions (ie. virtual
>>> host configuration directives).
>>> /r
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Nipuni Piyabasi Perera
>> Undergraduate
>> Department of Computer Science And Engineering
>> University of Moratuwa
>> Sri Lanka
> Undergraduate
> Sri Lanka
Undergraduate
Sri Lanka
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130606/127c48c9/attachment.html>
